Management Software
Anonymous
DCFM 10.1.0 trial auth problem
I downloaded the trial version of dcfm for both linux and windows, and seem to have over looked something somewhere with regard to a user id and password.
Reading through the install docs looks pretty straight forward for both platforms, but when I launch the gui both OS's require a user id and password.
The user id and password are not set during install, is there away to add this after the install or another step that is required before hand?
Every thing looks to be working fine, the "DCFM server console" comes up with everyting working and you are able to start and stop services.
External Moderator
Re: DCFM 10.1.0 trial auth problem
Edward
same question was answer here in the past. see follow threads
http://community.brocade.com/home/message/5648#5648
standard  username is Administrator
standard password is password
TechHelp24
