Management Software
Occasional Contributor
Brocade network Advisor Java problem not able to open the web tools
Hi,
I am facing the issue with the BNA
that I am not able to start the webtools i.e. Element manager for any switch thru BNA.
Also, I am not able to start the webstart console tool.
There is a java error
Error Could not parse launch file. Error at line 0.
<%@ page contentType="application/x-java-jnlp-file" info="JNLP Client" %>
<%@page import="com.brocade.dcm.system.Version"%>
<%@page import="com.brocade.dcm.util.LICParser"%>
JNLParseException[ Could not parse launch file. Error at line 0.]
    at com.sun.javaws.jnl.XMLFormat.parse(Unknown Source)
java.lang.NullPointerException
    at com.sun.deploy.xml.XMLParser.parseXMLAttribute(Unknown Source)
    at com.sun.deploy.xml.XMLParser.parseXMLElement(Unknown Source)
The Details of my environment are as  follows:-
1)Network Advisor release  Network Advisor 12.3.4 Enterprise
2)server It is a VM client dedicated for the Network Advisor Windows server 2008 R2 Standard  Edition Service Pack 1Intel(R) Xenon(R) CPU E7540 @ 2.00GHz (3 processors); RAM 12 GB, 64-bit Operating system
3)version of the FOS FOS 7.2.1d and  6..4.3d
4)Switch's  manage ? Switch type is of Brocade; B40, M48, 384, 192
5)Java Version 1.7_0.76
