Management Software
Occasional Contributor
BNA 12.1.5 problem - There are no values to display
[ Edited ]
Hi!
Today we’ve found that our Brocade Network Advisor do not shows any data in its widgets.
Our BNA installed on Linux Machine (Red Hat Enterprise Linux Server release 6.5 (Santiago)).
It seems that date on machine was wrong, I’ve fixed it and restarted server, but no data appears.
Contributor
Re: BNA 12.1.5 problem - There are no values to display
Probably check the volume space in your Operating system. Lot of logs generate from BNA which might your free disk space might filled up. Go to your linux server and check-
# df -h
-> check the used and free space.
-> Delete the log file or you can move the log file to another volume and create a sm-link to the log file.
That should work.
