Info & Feedback
New Member
Virtual Routing Interface
Receiving this error when trying to create virtual routing interface
LPK-ICX6610-01(config)#
LPK-ICX6610-01(config)#vlan 100
LPK-ICX6610-01(config-vlan-100)#router-interface ve 100
Invalid input -> router-interface ve 100
Type ? for a list
this is the output for show run
LPK-ICX6610-01(config)#sh run
running-config Current running-config
LPK-ICX6610-01(config)#sh running-config
Current configuration:
ver 08.0.10gT7f1
stack unit 1
module 1 icx6610-24-port-management-module
module 2 icx6610-qsfp-10-port-160g-module
module 3 icx6610-8-port-10g-dual-mode-module
stack-trunk 1/2/1 to 1/2/2
stack-trunk 1/2/6 to 1/2/7
stack-port 1/2/1 1/2/6
stack enable
vlan 1 name DEFAULT-VLAN by port
vlan 10 name LANUSER_GF by port
tagged ethe 1/1/3
vlan 20 name LANUSER_1F by port
vlan 100 name WLAN by port
tagged ethe 1/1/23 to 1/1/24
untagged ethe 1/1/12
hostname LPK-ICX6610-01
no ip dhcp-client enable
ip dhcp-server enable
ip dhcp-server pool vlan_100
dhcp-default-router 192.168.100.254
dns-server 1.9.1.9 8.8.8.8
excluded-address 192.168.100.1 192.168.100.10
lease 0 12 0
network 192.168.100.0 255.255.255.0
deploy
end
LPK-ICX6610-01(config)#sh ver
version System status
LPK-ICX6610-01(config)#sh version
Copyright (c) 1996-2014 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Dec 17 2014 at 18:25:28 labeled as FCXS08010g
(7280225 bytes) from Primary /FCXS08010g.bin
SW: Version 08.0.10gT7f1
Boot-Monitor Image size = 370695, Version:10.1.00T7f5 (grz10100)
HW: Stackable ICX6610-24
UNIT 1: SL 1: ICX6610-24 24-port Management Module
Serial #: BXP3843N00B
License: BASE_SOFT_PACKAGE (LID: dzrINJIpFFd)
P-ENGINE 0: type E02B, rev 01
UNIT 1: SL 2: ICX6610-QSFP 10-port 160G Module
UNIT 1: SL 3: ICX6610-8-port Dual Mode(SFP/SFP+) Module
800 MHz Power PC processor 8544E (version 0021/0023) 400 MHz bus
65536 KB flash memory
512 MB DRAM
STACKID 1 system uptime is 1 hours 54 minutes 55 seconds
The system : started=cold start
External Moderator
Re: Virtual Routing Interface
@2Y Comm
due a acquisition by Ruckus , ICX Switches are not longer supported by Brocade.
please post you question in they Community.
TechHelp24
Community Manager
Thanks @Antonio Bongiorno TechHelp24
@2Y Comm Please post your question over on the Ruckus ICX Forum Community.  They support the ICX.
Thanks
Jason
Community Manager
@jason_cmgr
