Info & Feedback
New Member
Bluetooth Problem related
After upgrading from windows 7 to 10 pro the bluetooth capabilities was lost and I can't use bluetooth any more after checking the device manager netwaork adapter I found that I have a Broadcom 43224AG 802.11a/b/g/draft-n Wi-Fi Adapter. So is there an update or a way to fix my problem!?
External Moderator
Re: Bluetooth Problem related
@Dr SberTo0o
you are here in wrong Community/Forum.
Such OS/Drivers compatibility for Embedded / Integrated ASIC's issue are not Supported from Broadcom.
Please post such question by Hardware / OEM PC Vendor Community.
TechHelp24
