Info & Feedback
New Contributor
Accepted Solution
ADX 1000 firmware upgrade from asr12502 to asr12502p.bin
I made a backup of the running config luckily.....I tried to update the firmware and now after issuing boot system flash secondary since that is where I copied it over to using a TFTP server the ADX -1000 won't even boot.....I just have green lights on the front of it...
I upgraded one of the 2 load balancers......I did a no sym-active also on both.....not sure what went wrong...please help
External Moderator
Re: ADX 1000 firmware upgrade from asr12502 to asr12502p.bin
ben.lyall@agfa.com
show as hardware issue
ADX is EOL
End of Support Date - however valid only with active maintenance contract - is Feb. 28, 2022
TechHelp24
New Contributor
Thank you for the info....
