Fibre Channel (SAN) Technical Documents
sanport
by Anonymous ‎09-14-2006 05:00 PM - edited ‎10-30-2013 01:06 PM (365 Views)
DETAILED DESCRIPTION
This script will log into each Fabric specified by swips and log into each switch and print a line for each port in the fabric. The line will contain switch name, port number, Type, State, Status and Notes. Notes contains the worldwide number of device connected to the switchport. This information can be used in script to determine what switch and port a wwn is connected to.
REQUIREMENTS
Operating System Only tested on Solaris
Interface Needs Brocade Scripting API 3.2.1/Active state perl 5.8.7
Fabric Operating System Tested with Fabric OS 4.4.0b
Other Might work with other sw versions.
NOTES (INCLUDING LIMITATIONS)
Only tested on local fabrics.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
