Fibre Channel (SAN) Technical Documents
reportSpaceDetails
by Anonymous ‎08-23-2005 05:00 PM - edited ‎10-30-2013 01:37 PM (424 Views)
DETAILED DESCRIPTION
Script : reportSpaceDetails
What it does : This script generates a report of mounted SAN Space details of hosts in question, where diskgroup names # are of type xxx.gnr.x . This however is not mandatory as all it is doing is matching against string # "gnr". If diskgroup name is something else then that can be used as the search string.
Usage : reportSpaceDetails -file -cl
use -cl switch if the hosts are clusters, in which case format the file as follows.
<clusternode1>,<clusternode2>
REQUIREMENTS
Operating System Linux,Solaris
Interface Perl
Fabric Operating System Unix
Other None
NOTES (INCLUDING LIMITATIONS)
Veritas VxVM needs to be used to manage the SAN disks as the script uses veritas VxVM commands(vxprint to be specific).
Works with linux & solaris hosts that are using SAN disks. The diskgroup name should be of type xxxx.gnr.xx . This however is not mandatory as all it is doing is matching against string "gnr". If diskgroup name is something else then that can be used as the search string..
This is quite useful to audit the hosts for SAN space utilization details and use the report for effective space utilization tasks.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
