Fibre Channel (SAN) Technical Documents
random
by Anonymous ‎03-15-2005 11:02 PM - edited ‎10-30-2013 01:43 PM (570 Views)
DETAILED DESCRIPTION  <br/>
<br/>
  1. random Script to snapshot random state and reload it at boot time.<br/>
  1. chkconfig: 2345 20 80
  2. description: Saves and restores system entropy pool for higher quality \
  3. random number generation.
  1. Source function library.
. /etc/rc.d/init.d/functions
random_seed=/var/run/random-seed
  1. See how we were called.
case "$1" in
start)
  1. Carry a random seed from start-up to start-up<br/>
  1. Load and then save 512 bytes, which is the size of the entropy pool<br/>
  if <a class="jive-link-adddocument" href="http://community.brocade.com/home/community-document-picker.jspa?communityID=2006&subject=-f%24random_seed+"> -f $random_seed </a>; then<br/>
    cat $random_seed &gt;/dev/urandom<br/>
  else<br/>
    touch $random_seed<br/>
  fi<br/>
  action "Initializing random number generator" /bin/true<br/>
  chmod 600 $random_seed<br/>
  dd if=/dev/urandom of=$random_seed count=1 bs=512 2&gt;/dev/null<br/>
  touch /var/lock/subsys/random <br/>
<br/>
  ;;<br/>
<br/>
stop)<br/>
  1. Carry a random seed from shut-down to start-up<br/>
  1. Save 512 bytes, which is the size of the entropy pool<br/>
  action "Saving random seed" dd if=/dev/urandom of=$random_seed count=1 bs=512 2&gt;/dev/null <br/>
<br/>
  rm -f /var/lock/subsys/random<br/>
  ;;<br/>
status)<br/>
  1. this is way overkill, but at least we have some status output...<br/>
  if -c /dev/random ; then
echo "The random data source exists"
else
echo "The random data source is missing"
fi
restart|reload)
  1. do not do anything; this is unreasonable<br/>
  :<br/>
  ;;<br/>
*)<br/>
  1. do not advertise unreasonable commands that there is no reason<br/>
  1. to use with this device<br/>
  echo "Usage: random {start|stop|status|restart|reload}"
exit 1
esac
exit 0
REQUIREMENTS
Operating System Linux
Interface Saves and restores system entropy pool for higher quality
Fabric Operating System Not Given
Other Not Given
NOTES (INCLUDING LIMITATIONS)
  1. random number generation.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
