Fibre Channel (SAN) Technical Documents
hotlinks
by on ‎03-27-2003 10:10 PM - edited on ‎10-30-2013 01:54 PM by Anonymous (2,041 Views)
DETAILED DESCRIPTION
NT/Windows 2000 GUI-based port performance program. This program identifies the ISLs inside your fabric, and allows you to choose from the critical ISLs inside your fabric. This program can also auto-choose the most critical ISLs as well. It will then graph the MB/s for each of the ISLs inside a line graph.
REQUIREMENTS
Operating System NT or Windows 2000
Interface GUI
Fabric Operating System One of the following at a minimum:
2.6.0d
3.0.2g
4.0.2b
Other Be sure you have the files nthapi_2.dll, xerces-c_1_7_0.dll, and brcdrpc.dll inside your path. Setting your path to the current directory should work.
NOTES (INCLUDING LIMITATIONS)
Steps
New Fabric logic
Select Fabric inside Fabric Window
Disply ISL
Two options
Choose top 5, then start
Control click to select multiple ISLs, check graph, click start
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
