Fibre Channel (SAN) Technical Documents
get_fibre.ksh
by Anonymous ‎04-25-2006 05:00 PM - edited ‎10-30-2013 01:23 PM (441 Views)
DETAILED DESCRIPTION
Uses korn shell and expect/tcl to telnet into a designated fibre switch, gets switch time, version, status, fan, temp and switch info an logs the output to a file. Tested on HP-UX only, but ought to be easily tranportable to any *nix version.
REQUIREMENTS
Operating System HP-UX or similar
Interface Any
Fabric Operating System Fabric OS 4 or higher
Other ksh, expect/tcl
NOTES (INCLUDING LIMITATIONS)
Latency in the telnet connection will result in the commands to the switch not always appearing in the log file ahead of the command output.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
