Fibre Channel (SAN) Technical Documents
disable_offline_ports
by Dan_Pollack on ‎08-07-2003 03:40 AM - edited on ‎10-30-2013 01:53 PM by Anonymous (1,171 Views)
DETAILED DESCRIPTION
Connect to a SAN, find out which ports report offline, and disable them. This will prevent new devices from accessing the SAN without the SAN POC or someone with the admin password from enabling the offline ports.
REQUIREMENTS
Operating System Solaris 2.X has been tested but should work anywhere the per API does.
Interface Basic Perl
Fabric Operating System One of the following:
2.6.0d
3.0.2f and higher
4.1
Other n/a
NOTES (INCLUDING LIMITATIONS)
n/a
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
