Fibre Channel (SAN) Technical Documents
configupms
by Anonymous ‎01-08-2006 04:00 PM - edited ‎10-30-2013 01:31 PM (432 Views)
DETAILED DESCRIPTION
This Perl Script is based on a script from the API. It walks to the /etc/hosts File and catches the Switchnames as far as they matches a pattern and an IP range. It uses the API to back up the Configfile of every Switch and stores it in a directory incl. its Date. A Logfile is written for sure, as well.
REQUIREMENTS
Operating System Solaris 8/9
Interface Perl, API
Fabric Operating System minimum is 2.6.x, 3.1.x 4.x
Other None
NOTES (INCLUDING LIMITATIONS)
Should run on any Solaris where Brocade API and PERL is available
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
