Fibre Channel (SAN) Technical Documents
chportstat
by Anonymous ‎07-31-2007 01:00 AM - edited ‎10-30-2013 01:02 PM (622 Views)
DETAILED DESCRIPTION
This script generate output for multiple disablig or enabling of unused ports, It include a 3 command; portcfgpersistent(enable/disable), portcfgtrunk and portcfgspeed, exp.
hportstat.pl (slot) (start port from) (end to port) (enable/disable) print chportstat.exe 1 0 10 disable - on blade 1 from port 0 to 10
REQUIREMENTS
Operating System All that support perl env.
Interface cmd
Fabric Operating System Brocade 12000 and 24000
Other chportstat.pl (slot) (start port from) (end to port) (enable/disable) print chportstat.exe 1 0 10 disable - on blade 1 from port 0 to 10
NOTES (INCLUDING LIMITATIONS)
None
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
