Fibre Channel (SAN) Technical Documents
WWN colon hotkey script
by Anonymous ‎04-12-2006 05:00 PM - edited ‎10-30-2013 01:24 PM (725 Views)
DETAILED DESCRIPTION
AutoHotkey (www.autohotkey.com) script to automate the addition and removal of colons in WWNs.
To use:
Press Ctrl-Alt-; or Ctrl-Alt-Shift-;
What happens:
If the text on the clipboard has any colons in it, all colons will be stripped out and the text will be pasted at the cursor. If the text has no colons, a colon will be inserted between every group of two characters.
REQUIREMENTS
Operating System Windows
Interface AutoHotkey (www.autohotkey.com)
Fabric Operating System Any
Other Requires AutoHotkey (www.autohotkey.com)
NOTES (INCLUDING LIMITATIONS)
If the clipboard contains text other than a WWN, the output will not be very meaningful. ;-)
Ctrl-Alt-Shift-; results in keystrokes being sent to the active window as opposed to using Windows' cut and paste function... this enables the use of this script in PuTTY (and similar) windows.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
