Fibre Channel (SAN) Technical Documents
Switchbkup
by Anonymous ‎08-19-2004 10:10 PM - edited ‎10-30-2013 01:48 PM (750 Views)
DETAILED DESCRIPTION
The goal of this script is to backup the 12K, 3800 and 3200 switch to a HP 9000 server running HPUX 11.00. The switches being backed up have FABOS 4.1.2b and 3.1.1c running on them. Create a directory called /configs on the target host, create a file in $HOME called .brocade with permission 600, run the script from /usr/local/bin via cron. to capture a log the crontab entry should read /usr/local/bin/switchbkup1 > /configs/brocade.log 2>&1
The script initially writes the files to / and then mv them to /configs/switchname.
REQUIREMENTS
Operating System HPUX 11.00
Interface No interface required
Fabric Operating System Tested against FAB OS 4.1.2b and 3.1.1c
Other Not Applicable
NOTES (INCLUDING LIMITATIONS)
Not Applicable
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
