Fibre Channel (SAN) Technical Documents
SAN Switches for Backups
by Anonymous on ‎06-07-2008 02:51 PM (285 Views)
Brocade SAN switches helped the environment to work better for Backups to happen faster.
Following scripts are being used in the environement to make them even more convenient to use.
#!/bin/sh
  1. fimselector
  1. fimselector
<master_server>
  1. - find the
available frozen image methods for each policy on the master server .
  1. fimselector
<master_server> <client> <policy> <filelist type: fs or raw>
  1. - find the available frozen
image methods for the client of the policy
  1. on the master server.
BPCLIENT=/usr/openv/netbackup/bin/admincmd/bpclient
master_server="$"
client="$"
policy="$"
fltype="$"
/usr/openv/netbackup/bin/admincmd/bpauthorize -test_admin
/dev/null
status=$?
if ; then
echo ""
echo "You do not have the proper authorization to perform" echo "this task. Please resolve and try again."
exit $
fi
if ; then
echo "master server name needs to be specified"
exit 1 fi
if && ; then
echo "find the available snapshot method for all policies on master: $ma
ster_server"
$ -M $master_server -auto_select -all
exit $?
fi
if ; then
echo "master: $master_server client: $client"
echo "policy name needs to be specified"
exit 1 fi
if ; then
echo "master: master_server client: $client policy: $policy"
echo "filelist type needs to be specified" exit 1
fi
echo "find the available snapshot method for policy: $policy on client: $client"
$ -M $master_server -client $client -policy $policy -auto_select -$flt
ype
exit $?
Regards,
Kishore
