Fibre Channel (SAN) Technical Documents
RouteTest
by on ‎09-12-2003 12:20 AM - edited on ‎10-30-2013 01:51 PM by Anonymous (876 Views)
DETAILED DESCRIPTION  <br/>
<br/>
With this utility, the user provides 2 wwns and it tells you the route that is currently being used between the 2 devices (you can also use domain,port references). After it gets the route - it will then check zoning to see if the 2 devices are in a zone together, tell you which one or say that the 2 devices cannot talk to each other due to zoning restrictions.   <br/>
<br/>
REQUIREMENTS  <br/>
<br/>
Operating System  Windows NT/2K <br/>
<br/>
Interface  CLI <br/>
<br/>
Fabric Operating System  One of the following at a minimum:<br/>
<br/>
2.6<br/>
<br/>
3.0 <br/>
4.0 <br/>
<p/>
Other  Usage: routetest <a class="jive-link-adddocument" href="http://community.brocade.com/home/community-document-picker.jspa?communityID=2006&subject=-ipIpAddress">-ip IpAddress</a> <a class="jive-link-adddocument" href="http://community.brocade.com/home/community-document-picker.jspa?communityID=2006&subject=-uUser">-u User-p Password -w1 wwn1 -w2 wwn2
NOTES (INCLUDING LIMITATIONS)
Windows binary
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
