Fibre Channel (SAN) Technical Documents
Problem with Switch Explorer and Java 1.7
by Anonymous on ‎10-17-2013 02:47 AM (1,357 Views)
I have four Brocade FC Switch Modules in IBM Blade Center. I want to use the Switch Explorer with java 1.7.0_45 and get an error message like: "Certificate could not be validated. The application will not run.". What can I do to solve this problem? On an old Workstation with java 1.7.0_25 erverythink works fine.
Comments
by Zhang
on ‎10-17-2013 06:06 AM
I got the same issue so I have to downgrade my java to 7 update 21
by Anonymous
on ‎10-22-2013 07:48 AM
I solved a similar problem with editing C:\Program Files (x86)\Java\jre7\lib\security\java.security and commenting out
   jdk.certpath.disabledAlgorithms=MD2, RSA keySize < 1024
as described in ISC Diary | Java and Old Hash Algorithms
by Anonymous
on ‎10-23-2013 09:13 AM
That solved my problem.
Thank you very much !!
by tibor.lencucha
on ‎07-09-2015 02:01 AM
Super ! :-)
