Fibre Channel (SAN) Technical Documents
Help: how to start rpcd after upgrade FOS 7.0.1
by Anonymous on ‎10-22-2012 11:25 PM (1,024 Views)
Hi to all,
I upgrade FOS from 6.4 to 7.0.1,  then SMI-agent can't connect to switch.
G3-08-SAN:FID128:admin> netstat -na | grep LISTEN
tcp        0      0 0.0.0.0:512             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:513             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:514             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:37              0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:199           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 :::80                   :::*                    LISTEN
tcp        0      0 :::22                   :::*                    LISTEN
tcp        0      0 :::23                   :::*                    LISTEN
unix  2           STREAM     LISTENING     1457   /tmp/webtools/tmp_0/31bafdb358bb3c0ce85fb24606c239e6
unix  2           STREAM     LISTENING     719    /tmp/ipadm_getset
unix  2           STREAM     LISTENING     721    /tmp/ipadm_notify
unix  2           STREAM     LISTENING     1509   /tmp/rcs_query0
rpcd can't start, no port 897 LISTEN
how to start rpcd ?
Could you help me to discovery the problem?
thanks
Comments
by
on ‎10-29-2012 09:47 AM
Hi wanglifu01,
I'm moving your document to the Data Center SAN Community so that you will get the most responses possible. This particular forum is for non-product related questions.
Thank you for participating in Brocade Communities!
Cheers,
Grace Chang
Global Community Manager
by
on ‎10-31-2012 01:25 AM
Hi,
Maybe you could check with command:
ipfilter --show
If there is any kind of ACL preventing that port from being accesible.
Rgds
by Anonymous
on ‎11-01-2012 12:15 AM
G3-08-SAN:FID128:admin> ipfilter --show
Name: default_ipv4, Type: ipv4, State: active
Rule Source IP    Protocol   Dest Port   Action
1     any                                            tcp       22     permit
2     any                                            tcp       23     permit
3     any                                            tcp      897     permit
4     any                                            tcp      898     permit
5     any                                            tcp      111     permit
6     any                                            tcp       80     permit
7     any                                            tcp      443     permit
8     any                                            udp      161     permit
9     any                                            udp      111     permit
10    any                                            udp      123     permit
11    any                                            tcp      600 - 1023     permit
12    any                                            udp      600 - 1023     permit
Name: default_ipv6, Type: ipv6, State: active
1     any                                            tcp       22     permit
2     any                                            tcp       23     permit
6     any                                            tcp       80     permit
by
on ‎11-01-2012 12:24 AM
WiKi DOC or Threads ?
by
on ‎11-01-2012 12:25 AM
As per my opinion, you should open a Thread instead a WiKi DOC about you question.
If I'm wrong, please ignore my comment.
Thank You.
by Anonymous
on ‎11-02-2012 06:36 PM
how to open a thread ?
thanks
