Fibre Channel (SAN) Technical Documents
Fix Configuration issues
by Anonymous ‎09-21-2005 04:00 PM - edited ‎10-30-2013 01:35 PM (446 Views)
D
ETAILED DESCRIPTION
The script prints the wwpns of Q-logic or Emulex cards in a familiar colon separated format that Brocade uses in the switchshow command output. This helps an engineer sitting in a remote location to compare the wwpns from the switch and the host and to be satisfied that the right host is plugged into the correct port.
REQUIREMENTS
Operating System Linux
Interface Perl
Fabric Operating System All
Other None
NOTES (INCLUDING LIMITATIONS)
It does not work in anyother operating system. It also does not work with other manufacturer's HBA cards.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
