Turn on suggestions
Showing results for
DETAILED DESCRIPTION
This script is used to check the file system monitoring in linux.
REQUIREMENTS
Operating System LINUX
Interface SAN
Fabric Operating System 4.1
Other None
NOTES (INCLUDING LIMITATIONS)
This script is used to check the file system monitoring in linux, when any file-system reaches the pre-defined size it will send an alert either in the form of SMS or mail. This script is written in ksh and requires at least a user level access.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
