Fibre Channel (SAN) Technical Documents
EVA_ALL_INFO
by Anonymous ‎02-26-2007 12:00 AM - edited ‎10-30-2013 01:15 PM (472 Views)
DETAILED DESCRIPTION
Script used to get info from a working EVA, for documentation. You will need to change the ip address to the ip address of the Management Server and the EVA name.
REQUIREMENTS
Operating System Any
Interface Not Applicable
Fabric Operating System Any
Other EVA 4000, EVA 6000 and EVA 8000
NOTES (INCLUDING LIMITATIONS)
After you have installed CM EVA and SSSU, Created all the Vdisks required then put the file EVA_ALL_info.bat into the SSSU install directory and run.
Edit the file changing the Management server name/IP and EVA name
This will output a file called full_disk_info.xml
edit this file a remove all the lines than look similar to this \Virtual Disks\HP-UX\WLUX01_ALPHA_62\ACTIVE information:
.Then insert at the very top of the XML file and at the very bottom of the file.
now open with excel.
open as a xml list
Column B is the Vdisk Name ( select all and copy to new excel spreadsheet )
Column E is the UUID Number ( select all and copy to the new excel spreadsheet )
Column AP is the Disk Group ( Select all and copy to the new excel spreadsheet )
Column R is the Vdisk Size in GB ( Select all and copy to the new excel spreadsheet )
Column AD is the Vraid type ( Select all and copy to the new excel spreadsheet )
Column AR is the preferred path
Column AO is the OS Unit ID
Column AJ states whether the disk is presented or not
Column AL is the Lun number
Column AM is the Host of where the Vdisk is presented
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
