Fibre Channel (SAN) Technical Documents
Configuration
by on ‎03-28-2008 12:00 AM - edited on ‎10-30-2013 01:15 PM by Anonymous (503 Views)
DETAILED DESCRIPTION  <br/>
<br/>
This is a Command line version of the ConfigUpload and ConfigDownload. This utility makes it easy to do simple config (upload/download) to switches using a DOS command line interface. This executable has options to allow reboots after configdownload, filter the config files, and download some or all parameters depending on the reboot parameter.  <br/>
<br/>
REQUIREMENTS  <br/>
<br/>
Operating System  NT, Windows 2000 <br/>
<br/>
Interface  Command line and TCP connection to the switch <br/>
<br/>
Fabric Operating System  One of the following at a minimum:<br/>
<br/>
2.6.0d<br/>
<br/>
3.0.2g <br/>
4.0.2b <br/>
<p/>
Other  NT, DOS Command line tool, make sure you have all these files inside your path: nthapi_2.dll, xerces-c_1_7_0.dll, and brcdrpc.dll. Setting your path to the current directory, should work. <br/>
<p/>
NOTES (INCLUDING LIMITATIONS)  <br/>
<br/>
Usage:<br/>
configuration &lt;-upload | -download&gt; <br/>
<a class="jive-link-adddocument" href="http://community.brocade.com/home/community-document-picker.jspa?communityID=2006&subject=allow-reboot">allow-reboot</a> <a class="jive-link-adddocument" href="http://community.brocade.com/home/community-document-picker.jspa?communityID=2006&subject=filter-rebootprefixes">filter-rebootprefixes</a><br/>
<a class="jive-link-adddocument" href="http://community.brocade.com/home/community-document-picker.jspa?communityID=2006&subject=-uusername">-u username</a> <a class="jive-link-adddocument" href="http://community.brocade.com/home/community-document-picker.jspa?communityID=2006&subject=-ppassword">-p password
(upload=switch-to-host, download=host-to-switch)
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
