Fibre Channel (SAN) Technical Documents
Commands for basic FOS troubleshooting
by Anonymous on ‎03-25-2010 12:29 AM (339 Views)
Disclaimer: The information in this Contribution is provided “AS IS,” without warranty of any kind.
The author reserves the right to make changes to this document at any time, without notice, and assumes no responsibility for its use.
The author shall have no liability or responsibility to any person or entity with respect to any loss, cost, liability, or damages arising from the information contained in this contribution.
There are lots of brocade commands that come handy when troubleshooting a fabric related problems. We divide these into
Marginal Links
switchshow - Indicators like no light or In_sync will be displayed
portshow <port> - Provides report on errors on a port
porterrshow - provides gist of port errors, look for delta of counters
portstatsshow <port> - Provides details of port errors
portstats64show - Extension of portstatsshow when 32 bit counters do not suffice, look for tim_txcrd_z to observe BB_credit deltas
fabriclog -s - Helps isolate flapping ports, look out for offline and online sequences
sfpshow - Provides information on SFP and their state, check for power
Zoning
cfgshow - Displays zoning configuration
defzone --show  - Shows default zone settings
nsshow -t - Display name server entries with additional details
nodefind <alias> - To find specific device in fabric
nodefind <WWPN> - To find specific device in fabric
fcping <initiator> <target> - helps isolate end to end device connectivity and also an easy method to validate zoning
Licensing
licenseshow
Firmware Download
firmwaredownloadstatus
firmwareshow
version
Configuration
configdefault - To reset switch configuration to default
configdownload - To download a previously uploaded config file
switchshow - Lists connection information as well first indicator of fabric segmentations
errshow -r - Look for config events, match events with list in Brocade Message reference guide for suitable actions
fabstatsshow - flags any parameter mismatch during merging
fabricshow - Helps identify domain id conflicts and gives an overview of all fabric members
configure - To set correct switch and flow control parameters
portcfgshow <port number> - Display port configuration
portcfgspeed <port number> - Set or show port speed
portcfgdefaults <port number> - Set port settings to default
portcfgpersistentenable <port> - To enable port permanently
portcfgpersistentdisable <port> - To disable port persistently (across reboots)
portdisable
portenable
portcfgeport - Disable E port
portcfglport - Lock port to L port
portcfggport - Lock port to E or F port
Log collection
supportshow
supportsave
