Fibre Channel (SAN) Technical Documents
Chassis is not ready for management now. Please try after some time.
by on ‎10-16-2009 10:02 PM (2,246 Views)
Notice: The information in this Contribution is provided “AS IS,” without warranty of any kind.
The author TechHelp24 reserves the right to make changes to this document at any time, without notice, and assumes no responsibility for its use.
The author TechHelp24 shall have no liability or responsibility to any person or entity with
respect to any loss, cost, liability, or damages arising from the information contained in this contribution.
Some user reported at several times about the problem
"Chassis is not ready for management now. Please try after some time."
Here is the Workaround.
Log as root and execute
Brocade4100:root> /fabos/libexec/webdconfigure
HTTP attributes (yes, y, no, n): y     set to y or yes
HTTP Restart (yes, y, no, n): y        set to y or yes
HTTP enabled (yes, y, no, n):         must be set to yes also enable.
ErrorLog Enabled (yes, y, no, n):
AccessLog Enabled (yes, y, no, n):
SSLLog Enabled (yes, y, no, n):
HTTP Port: (1..60000)
Secure HTTP Port: (1..60000)
HTTP IsAlive Check Enabled (yes, y, no, n):     must be set to yes
HTTP Max HeapSize: (256..1024)
webtools attributes (yes, y, no, n):
cal attributes (yes, y, no, n):
Exit from /webdconfigure and try as root "hareboot"
Comments
by Anonymous
on ‎09-04-2012 08:24 AM
This procedure is online for switch?
Thanks,
Wellington
by
on ‎09-04-2012 08:47 AM
Hi,
Yes, it is online for the switch. It only affects HTTP server and weblinker process which are restarted.
Rgds
