Fibre Channel (SAN) Technical Documents
Batch Port Namer
by Anonymous ‎03-21-2006 05:00 PM - edited ‎10-30-2013 01:28 PM (416 Views)
DETAILED DESCRIPTION
This perl script can be used to (re)name switches ports.
To use it, you need to create a file / list in the following format :
switch_ip_address:slot:port:port_name
And run 'cat | portname.pl'
This script creates a log, called (by default) output.log.
To use this script, you must change the following values :
  • login
  • password
  • prompt
You can not "invent" them, those must be the ones reflecting your existing configuration.
REQUIREMENTS
Operating System Any supporting Perl & Net::Telnet
Interface Perl 5.8
Fabric Operating System >4
Other None
NOTES (INCLUDING LIMITATIONS)
This script is provided as is, it means I do not endorse any responsibility for whatever can occur using it (your wife leaves you, your car is broken, you do not have coffee, no more coke available, switch burning, ...) :-)
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on January 23, 2008, on behalf of the author.
Contributors
