Occasional Visitor
we get no connection via management port on a fc switch 6510. any idea%3F
hi,
we get no access via management port on a fc switch 6510, the link is available.
any idea ?
Broadcom Moderator
Re: we get no connection via management port on a fc switch 6510. any idea%3F
Hi Andreas,
do you have access via the serial console?  Have you tried to unplug and replug the ethernet cable? Does the switch answer pings?
