New Contributor
too many errors enc_out
Hello,
we have a switch in a fabric with too many errors on one port.
          frames      enc    crc    crc    too    too    bad    enc   disc   link   loss   loss   frjt   fbsy  c3timeout
       tx     rx      in    err    g_eof  shrt   long   eof     out   c3    fail    sync   sig                 tx    rx
  0:   18.3m  16.9m 519.0k 149.0k  77.2k 873      0     71.8k 753.5m   4.6k   0      0      0      0      0    973      0
This port is E-port and on other side of ISL there are only a few port errors (c3timeout_tx and disc_c3).
Is possible to say where is a problem - SFP or cable?
Thanks for any help
Martin
Valued Contributor
Re: too many errors enc_out
the most important non-zero error counter shown here is crc_g_eof. i'd start replacing with the opposite sfp.
New Contributor
alex,
thank you for your response. I'll try it.
martin
