Anonymous
target and initiator at the same port
Hi Experts,
Understand that, brocade is support the single port with same target and initiator mode.
May I know which FOS version is support  for this feature? May I know how to perform it? I'm using 2G of 8 Port switch.
Anonymous
Re: target and initiator at the same port
Hi Meiyang,
Your question is not clear.
But if I understand it correctly, the answer is any FOS would support this. You can connect any port to an initiator or target.
Regards,
Biju Krishnan
TechHelp24
Email: bkrishnan@techhelp24.com
Site: www.techhelp24.com
Anonymous
which sw type it is? there is no such concept of initiator/target port liek in storage you have to enable it . Biju is right any FOS will support this concept. you can connect any inititor or target port to any port but best practice is to connect the 2 in a  quad.
