New Contributor
Accepted Solution
switch to switch FOS compatibility check
Hello,
Brocade 3016 (actually a IBM blade center) running FOS v4.4.1a
I want to connect this blade center switch to brocade 300 with  v7.2.1d
where to check if this combination can work ?or not ?
please dont say FOS release notes.. I spent 30mins , still not able to find right document or release notes..
please be specific to you answer or send me link to open release notes
External Moderator
Re: switch to switch FOS compatibility check
[ Edited ]
@Allu
--->>>please dont say FOS release notes....
Indeed FOS Interoperabilty is listed in "Release Notes"
latest supported FOS on 3016 is v5.0.5f.
FOS 7.x or higher cannot interoperable with FOS 5.x and is not longer supported.
both 3016, FOS 4.x and all 5.x are end of life.
TechHelp24
New Contributor
[ Edited ]
Great. Thank you.
Your reply is very useful.
Appreciate your help and Thanks for your time.
https://my.brocade.com/ -  - then download and search for FOS  ( found a way how to find it now)
Thanks
Nanda
