Anonymous
switch ip and cp ip question
Hi techhelp24:
Thks for your help about my sw ip and cp ip problem.
Iwould like to know more technical details about the switch IP and cp IP.
1 "IP Addresses, are not for manamegent only." , what's their real function
2 I am curious to know the reason that I must set switch ip and cp ip in the same subnet.What can happen if I set them in the different IP ?
I can not access CP0 or cp1 from LAN if they are in different subnet .more points?
Thks a lot.
External Moderator
Re: switch ip and cp ip question
It is not necessary you Open a new threads for a same question.
close this one, and continue with the preview threads please.
thank you.
TechHelp24
