Anonymous
supportsave running failed
hi,expert :
    pls help me , i cannt execut the supportsave, the following error messages:
1A-N3:FID128:wlyx1.bf> supportsave
This command collects RASLOG, TRACE, supportShow, core file, FFDC data
and other support information from both active and standby CPs
and then transfer them to a FTP/SCP/SFTP server or a USB device.
Local CP, remote CP and BPs' information will be saved,
but supportShow information is available only on the Active CP.
This operation can take several minutes.
NOTE: supportSave will transfer existing trace dump file first, then
automatically generate and transfer latest one. There will be two trace dump
files transferred after this command.
OK to proceed? (yes, y, no, n): [no] y
Host IP or Host Name: 80.7.16.155
User Name: aaa
Password:
Protocol (ftp | scp | sftp): ftp
Remote Directory: /
Saving support information for switch:1A-N3, module:RAS...
Saving support information for switch:1A-N3, module:CTRACE_OLD...
SupportSave Exiting , signal = 13
External Moderator
Re: supportsave running failed
wuf,
is -->>Host IP or Host Name: 80.7.16.155  the correct FTP Server ?
If yes, is the server accessible from the Switch you want execute supportsave ?
additional please check if "supportftp" is configured.
TechHelp24
Anonymous
hi,expert:
            the supportftp dont configure.
External Moderator
[ Edited ]
wuf,
--->>hi,expert:
            ---->>>the supportftp dont configure.
what you want to say ?
TechHelp24
