Anonymous
supported firmware
Hello,
Is there a link with supported firmware for all Brocade FC Switches? I checked the web site and the data sheets under the switches I am interested in but I was unable to find the latest supported firmware levels.
Is there a recommendation for a fabric with Blade switches and Brocade 5300 as core switches. Will it be the same FOS for every switch in the fabric ?
For example I am interested whether FOS 7.0.1 is supported on Brocade 5470 (IBM Blade switch)
Any help on this is appreciated.
External Moderator
Re: supported firmware
FOS Compatibility and Interoperability on Supported Switches is listed in Release Notes.
->Will it be the same FOS for every switch in the fabric ?
Is suggested, - when supported - to have same FOS Release Fabric wide.
TechHelp24
Anonymous
hi,
if am right the type of that switch is 75 > M5424 , then even FOS 720a supports Brocade 5470
regards,
