Anonymous
silkworm 7500 will not boot
got my hands on a 7500  and when i console into the unit this is all I get.
I am pretty sure its hosed but wanted a second opinion
thanks in advance for any help
The system is coming up, please wait...
Read board ID of 0x8b from addr 0x23
Read extended model ID of 0x1f from addr 0x22
Matched board/model ID to platform index 9
Matched board/model ID to platform index 10
Checking system RAM - press any key to stop test
Checking memory address: 00100000
System RAM test using Default POST RAM Test succeeded.
Press escape within 4 seconds to enter boot interface.
Booting "Fabric Operating System" image.
Resetting ATA controller.
ATA controller reset failed.
Read map file failedd
Retry reading the first kernel image
ATA()0x9d607's entry point is too small (0x00003DB8 < 0x00100000)
ATA()0x1b0748's entry point is too small (0x00003DB8 < 0x00100000)
OSLoader contains no bootable devices.
                                      ÿ
Anonymous
Re: silkworm 7500 will not boot
update to the issue, while in console and it prompts me to press "escape" to enter boot interface
yeah it doesn't respond to that at all, even when i tried binding a different key to the escape button, or use a different computer or terminal program. any ideas how to load the cf card from a windows machine or is this dead?
External Moderator
there is no way to reload FOS in a CF, excepted with a recovery Image and some other tools, such tools are available from Brocade Support only under certain very Critical circumstance and only with a valid maintenance Contract
-windows is unable to handle the partition's Present on CF or recovery then.
-we discussed such problem in the past here in the Community, many topic are available.
Hints: Try to boot in root from a second partition with -s, if you are familiarly with Linux, here are diverse command to restart/reload the partition.
have a fun.
TechHelp24
