Turn on suggestions
Showing results for
10-18-2017 04:39 AM
Hi all
I am going to be setting up a FCIP configuration between 3 sites, and am not sure about the FCIP tunnels
Site A - 2 FCIP 7800's - "fcip fabricA" switch and "fcip fabricB" switch
Site B - 2 FCIP 7800's - "fcip fabricA" switch and "fcip fabricB" switch
Site C - DR site - 2 FCIP 7800's "fcip fabricA" switch and "fcip fabricB" switch
On the FC side of the switches, the arrays being replicated will be zoned to each other accordingly
I need Site A to have a tunnel to Site C - it will use VE_port 16 with 2 circuits, circuit 0 on Ge0 and circuit 1 on Ge1 on switch 1, and on switch 2 the same deal
for Site B to Site C, do i set up VE_port 16 there also, or should i explicity define the next VE_port 17 for this tunnel, seeing that Site A to Site C is using VE_port 16?
And to add to this, i believe i need to have Site A and Site B setup with a tunnel (not sure on this yet)
Regular site to site FCIP is not difficult, just adding in a 3rd Site is where i am having some diffculty mapping out what i need to do
Thanks in Advance
James
Solved! Go to Solution.
10-20-2017 07:19 AM
James,
You are correct.
The VE_port is a local port identifier on each unique switch.
It is ideal to use separate VE_ports to connect tunnels between 7800s at different locations.
For each fabric, You can use VE_port 16 on each site A and B switch, and use separte VE_ports on Site C to connect to each site. (VE_port 16 to connect from Site C to Site A, and VE_port 17 to connect Site C to site B)
- Or you could use VE_port 16 on each switch pair connecting Sites A and Site C, and use VE_port 17 on each switch pair to connect Site B and Site C.
I hope this helps.
Best regards,
Larry
