New Contributor
radius authentication leads to "Connection reset by peer"
I moved a a brocade 4100 FOS v6.4.3d to radius authentication but I got this message trying to connect:
"Read from remote host xyz: Connection reset by peer
Connection to xyz closed."
Although on the radius server the access is granted and also a correct profile is commited.
New Contributor
Re: radius authentication leads to "Connection reset by peer"
an incorrect template for radius packets on a juniper firewall between switch and radius server caused unwanted drops...
Former Brocadian
frank.schade... thank you verify much for including what the cause was on this.
Regards,
Mike Eversole
Brocade Community Manager
