Anonymous
query on FCIP implementation on FX8-24 blade DCX switch?
Hi..i m newbie for FCIP implementation.. i gone through FCIP admin guide before we start configuring FCIP.but it got failed on first step(configuring VEX port)
we planned to do FCIP between two FX8-24 blades on slot 12 of two DCX switch.we have disabled ge 0 to ge 9 ports.
switch dont have any logical switch and has no virtual fabrics. we planned to use Ge port 0 on each switch.
>this is first command we fired for VEX ports configuration---portcfgvexport 12/12 -a 1
FID128:admin> portcfgvexport 12/12 -a 1
Error: EX-Port related operations are allowed on base switch only, not on any other logical switch.
hw to configured VEX ports? should i try portcfgvex ports 12/12 -a 1 -f 2 (since fabric id is 2)
>should we disable virtual fabric since virtual fabric is enabled?
>VE ports(12-31) on FX8-24 blade..so it means VE ports 12-21 for ge 0 to ge 9..so VE ports can be configured on any ge ports?rite or do we have any rules for this.?
   since i heard we have to use VE port 16 since its points to ge port 0.
thanks for your valuable time in responding!
External Moderator
Re: query on FCIP implementation on FX8-24 blade DCX switch?
hi,
I'm experienced with Brocade 7800, but no with FX8-24 Blade.
simple question, have you all required License Installed ?
--->>>>should we disable virtual fabric since virtual fabric is enabled?
any such restrictions is unknow to me.
--->>> Hi..i m newbie for FCIP implementation..
Since you are not familiarly with FCIP,  would suggest you use Brocade BNA, ( Trial Enterprise ) that help you to configure the Tunneling in short time.
TechHelp24
Anonymous
yes. we have installed license on that switch.
what does this error mean?
hw to configured VEX ports? should i try portcfgvex ports 12/12 -a 1 -f 128 - d 2 (since fabric id is 128 and domain id 2)
