Turn on suggestions
Showing results for
07-19-2018 03:43 AM
Hi,
i have installed new SAN switch Brocade BR-300 24 port. i can login with admin account but not able to login with root user with default password. the issue i am not able to access web interface, and even no error message. Java is not a issue as i have existing brocase switch working fine.
Kernel: 2.6.34.6
Fabric OS: v8.1.0b
Solved! Go to Solution.
07-19-2018 04:44 AM
->i have installed new SAN switch Brocade BR-300 24 port.
are you sure the Switch is Brocade 300 ???
1) Brocade 300 is not supported by FOS 8.x
2) in FOS 8.x is root by default disable
3) log as admin in command line and executed the command
"rootaccess --set all"
07-21-2018 11:31 PM
07-21-2018 11:33 PM
07-23-2018 06:18 AM
hi there
Brocade 300 [71] is supported even by FOS 8.1.2
provide us output of command: userconfig --show -r root
rgds
07-23-2018 06:34 AM
--->>>Brocade 300 [71] is supported even by FOS 8.1.2
From Release Notes 8.0.x
Deprecated hardware
The following Brocade devices are no longer supported starting with this release.
• 300, 5100, 5300, 7800, VA-40FC, Brocade Encryption Switch, DCX, DCX-4S
• 5410, M5424, 5430, 5431, 5432, 5450, 5460, 5470, 5480, NC-5480
From Release Notes 8.1.2
Hardware Support
Supported devices
The following devices are supported in this release:
G610, G620, X6-8, X6-4
6505, 6510, 6520, DCX8510-8, DCX8510-4
6542, 6543, 6545, 6546, 6547, 6548, M6505, 6558
7840
07-23-2018 06:40 AM
@Antonio
before I replied I checked FOS 8.2.1a files and yes , it supports brcd300,5100 and 4 other older types
otherway I wouldnt write it.
07-23-2018 06:55 AM
