Anonymous
Accepted Solution
problem in zoning log I need help
I have a brocade switch 4100 with O.S 5.2.0a
when I collect supportshow & supportsave
I get the following
switchstatusshow:
Switch Health Report Report time: 11/03/2013 12:50:14 PM
Switch Name: S1
IP address: 192.168.119.1
SwitchState: HEALTHY
Duration: 963:37
Power supplies monitor HEALTHY
Temperatures monitor HEALTHY
Fans monitor HEALTHY
Flash monitor HEALTHY
Marginal ports monitor HEALTHY
Faulty ports monitor HEALTHY
Missing SFPs monitor HEALTHY
All ports are healthy
switchshow:
switchName: S1
switchType: 32.0
switchState: Online
switchMode: Native
switchRole: Subordinate
switchDomain: 11
switchId: fffc0b
switchWwn: 10:00:00:05:1e:03:f5:02
zoning: OFF
switchBeacon: OFF
and show analysis
Effective Configuration Warnings Zoning is OFF on this switch
But when I use "switchshow"
and "cfgactvshow"
it shows that there are an active zone already running
I need your help as soon as possible
Thanks
Anonymous
Re: problem in zoning log I need help
Have you tried enabling a zone configuration again?
Valued Contributor
Hi,
If you the switch is working without issues, that may just be a cosmetic issue. The FOS release is veeery old, so and upgrade would be a good choice.
Rgds
