TAO
Contributor
portcgspeed set to 8Gbps, BNA showing port speed as 4Gbps
Hi,
I have set some ISL ports hard set to 8Gbps however BNA port properties is showing the port speed as 4Gbps. I noticed the problem when looking at the historical perfromance graphs in BNA where 100% was equating to 4Gbps.
I have two fabrics with the same config, fab 1 is showing the issue in BNA but fab 2 isn't.
Any thoughts?
Thanks
Broadcom Moderator
Re: portcgspeed set to 8Gbps, BNA showing port speed as 4Gbps
Hi,
have you tried rediscovering the fabric in BNA?
CLIs Switchshow does show the fixed 8G speed?
CLIs sfpshow -f does also show correct information?
TL
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided solely as a convenience for Brocade customers. All systems and all networks are different and unique. If you have a service affecting network problem, please open a TAC service request for service through Brocade, or through your OEM equipment provider.
