Anonymous
port license help
Hello all,
I am new to brocade switches. I have a simple question. How do I display which ports are licensed on my switch? Command line please.
I want the command that will show me something similar to the web version.
See attachment and highlighted area.
Thanks,
OM
External Moderator
Re: port license help
the simple "switchshow" command, show the switch and all the Port.
the Output show all enabled Online/Offline and disabled Port.
with "licenseshow" can you verify the installaed license.
TechHelp24
Anonymous
Thanks for the response.
I know about these two commands. The problem is "switchshow" doesn't indicate which ports are licensed (looking for a field in the output that has the title licensed and idenifites each port like my attachment) and "licenseshow" give me a license, but that doesn't tell me much on what is licensed.
admin> switchshow
Area Port Media Speed State
  0   0   id    N4   Online    E-Port
  1   1   id    N2   Online    F-Port
  2   2   id    N2   Online    F-Port
admin> licenseshow
    Web license
    Zoning license
    Fabric license
    Fabric Watch license
    Ports on Demand license - additional 8 port upgrade
Maybe I need to ask my question differently. How do I know if the port is "not licensed" is there some indication?
Anonymous
for not licensed port switchshow should report something like that :
24  24   531f00   --    N8   No_Module   FC  (No POD License) Disabled (Persistent)
hope this helps
Kind regards;
david
Anonymous
Thanks dmercier that is exactly what I wanted to know.
OM.
Anonymous
licenseport --show
show which ports are licensed and how many licenses
Anonymous
Hi Andrey,
F.Y.I. My question was answered, but I tried your command anyway and this is what I got.
licensePort --show
licensePort failed : this command is not supported on this product.
Thanks,
Tony
Anonymous
Perhaps this command is applicable to certain switches
In my case:
licenseport --show
  20 ports are available in this switch
   No POD licenses are installed
     Dynamic POD method is in use
  10 port assignments are provisioned for use in this switch:
        10 port assignments are provisioned by the base switch license
      *  5 port assignments are added if the first POD license is installed
      *  5 more assignments are added if the second POD license is installed
  10 ports are assigned to installed licenses:
        10 ports are assigned to the base switch license
  Ports assigned to the base switch license:
     0, 1, 3, 4, 7, 8, 9, 10, 11, 12
  Ports assigned to the first POD license:
     None
  Ports assigned to the second POD license:
     None
  Ports not assigned to a license:
     2, 5, 6, 13, 14, 15, 16, 17, 18, 19
   0 license reservations are still available for use by unassigned ports
My brocade model is 5470, it in the bladecenter H
Anonymous
Hi Andrey,
Thanks for the command. I will keep it in mind in case we purchase a switch in which I am able to use it.
Tony
