Contributor
port can't get serial data and Can not read Serial Data!
Good afternoon.
Factory san works, no problem.
But confusing conclusion following commands. (
port  can't get serial data and Can not read Serial Data!)
on those ports that are involved and working in a factory
Please suggest whether this is a mistake or not worth paying attention to it.
Thanks in advance.
SFP Serial ID Information
Port  0: id Can not read Serial Data!
Port  1: id Can not read Serial Data!
Port  2: id Can not read Serial Data!
Port  3: id Can not read Serial Data!
Port  4: id Can not read Serial Data!
Port  5: id Can not read Serial Data!
Port  6: id Can not read Serial Data!
Port  7: id Can not read Serial Data!
Port  8: id Can not read Serial Data!
Port  9: id Can not read Serial Data!
Port 10: id Can not read Serial Data!
Port 11: id Can not read Serial Data!
Port 12: id (sw) Vendor: FINISAR CORP.    Serial No: PCB3UPX          Speed: 100,200,400_MB/s
Port 13: id Can not read Serial Data!
Port 14: --
Port 15: id (sw) Vendor: FINISAR CORP.    Serial No: PCB3X8S          Speed: 100,200,400_MB/s
sfpshow -all
port 14: can't get serial data
Port 15:
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 150c402001000000 100,200,400_MB/s M5,M6 sw Inter_dist
Encoding:    1    8B10B
Baud Rate:   42   (units 100 megabaud)
Length 9u:   0    (units km)
Length 9u:   0    (units 100 meters)
Length 50u:  15   (units 10 meters)
Length 62.5u:7    (units 10 meters)
Length Cu:   0    (units 1 meter)
Vendor Name: FINISAR CORP.
Vendor OUI:  00:90:65
Vendor PN:   FTLF8524P2BNV
Vendor Rev:  A
Wavelength:  850  (units nm)
Options:     0032 Loss_of_Sig,Tx_Disable
BR Max:      0
BR Min:      0
Serial No:   PCB3X8S
Date Code:   070914
Temperature: 37 Centigrade
Current:     7.338 mAmps
Voltage:     3336.7 mVolts
RX Power:    -40.0  dBm (0.1 uWatts)
TX Power:    -4.6  dBm (344.9 uWatts)
Anonymous
Re: port can't get serial data and Can not read Serial Data!
Would you mind giving us the output of a "switchshow" command?
I am suspecting that this is a blade enclosure module, and therefore does not use SFPs for the internal ports.
Contributor
SAN_Switch_2:adm> switchshow
switchName:     SAN_Switch_2
switchType:     34.0
switchState:    Online
switchMode:     Native
switchRole:     Subordinate
switchDomain:   2
switchId:       fffc02
switchWwn:      10:00:00:05:1e:05:e0:71
zoning:         ON (SAN)
switchBeacon:   OFF
Area Port Media Speed State     Proto
  0   0   id    N4   Online           F-Port  50:05:07:63:06:18:03:44
  1   1   id    N4   Online           F-Port  50:05:07:63:06:18:43:44
  2   2   id    N4   Online           F-Port  20:25:00:a0:b8:5a:00:ee
  3   3   id    N4   Online           E-Port  10:00:00:05:1e:5e:0c:7f "SAN_Blade                                                            _2_2"
  4   4   id    N4   Online           F-Port  50:05:07:63:06:13:83:44
  5   5   id    N4   Online           F-Port  50:05:07:63:06:13:c3:44
  6   6   id    N4   Online           L-Port  1 public
  7   7   id    N4   Online           F-Port  3 NPIV public
  8   8   id    N4   Online           E-Port  10:00:00:05:1e:5e:0d:60 "SAN_Blade                                                            _2_1"
  9   9   id    N4   Online           E-Port  10:00:00:05:1e:06:bf:48 "SAN_Blade                                                            _1"
10  10   id    N4   Online           E-Port  10:00:00:05:1e:06:bf:48 "SAN_Blade                                                            _1"
11  11   id    N4   Online           E-Port  10:00:00:05:1e:05:e0:0d "SAN_Switc                                                            h_1" (upstream)
12  12   id    N4   Online           F-Port  21:00:00:e0:8b:91:72:cb
13  13   id    N4   Online           F-Port  21:00:00:1b:32:83:62:68
14  14   --    N4   No_Module
15  15   id    N4   No_Light
SAN_Blade_1:adm> switchshow
switchName:     SAN_Blade_1
switchType:     37.1
switchState:    Online
switchMode:     Native
switchDomain:   3
switchId:       fffc03
switchWwn:      10:00:00:05:1e:06:bf:48
zoning:         ON (SAN)
switchBeacon:   OFF
  0   0   --    N4   No_Module
  1   1   cu    AN   No_Sync
  2   2   cu    AN   No_Sync
  3   3   cu    N4   Online           F-Port  10:00:00:00:c9:66:2b:56
  4   4   cu    AN   No_Sync
  5   5   cu    AN   No_Sync
  6   6   cu    AN   No_Sync
  7   7   cu    N4   Online           F-Port  21:00:00:24:ff:41:07:00
  8   8   cu    AN   No_Sync
  9   9   cu    AN   No_Sync
10  10   cu    AN   No_Sync
11  11   cu    AN   No_Sync
12  12   cu    AN   No_Sync
13  13   cu    AN   No_Sync
14  14   cu    AN   No_Sync
15  15   id    N4   Online           E-Port  10:00:00:05:1e:05:e0:0d "SAN_Switc                                                h_1"
16  16   id    N4   Online           E-Port  10:00:00:05:1e:05:e0:0d "SAN_Switc                                                h_1" (upstream)
17  17   id    N4   Online           E-Port  10:00:00:05:1e:05:e0:71 "SAN_Switc                                                h_2"
18  18   id    N4   Online           E-Port  10:00:00:05:1e:05:e0:71 "SAN_Switc                                                h_2"
19  19   --    N4   No_Module
SAN_Blade_1:adm>
Anonymous
On SAN_Switch_2 you should be able to get SFP data for all ports (except port 14). Try with a 'sfpshow PORT -f'.
On SAN_Blade_1 you will only get SFP (serial) data for ports 0, 15, 16, 17 and 18. The other ports will fail with "can't get serial data" since they are direct connected copper ports.
Best regards
Contributor
I apologize, but perhaps incorrect syntax
SAN_Switch_2:adm> sfpshow 2  -f
sfpshow: Invalid input parameters
Valued Contributor
Hi,
What FOS is running on the switchs? I've seen that behavior in switchs with an old FOS. Upgrade the firmware and let us know if the issue remains.
Rgds,
Felipon
Contributor
Fabos Version 6.2.2d all switch (4020, E200)
Maximum version that was established when the update on more recent firmware error occurred.
Valued Contributor
It seems that "-f" option is not supported in 6.2.2d.
You could try to reseat the SFP and issue the sfpshow afterwards to see if the info is correclty collected.
Contributor
Good afternoon.
Once again stood up and pulled the transceiver sfp of each Switch.
Switches began to show
sfpshow   on  Camondo characteristics transceiver.
Many thanks for the advice.
But the question of why it was necessary to make manipulation of the transceiver? And what problems might occur with transceiver (port can't get serial data and Can not read Serial Data!)?
SAN_Blade_1: adm> sfpshow
Port 0: -
Port 1: cu Can not read Serial Data!
Port 2: cu Can not read Serial Data!
Port 3: cu
Port 4: cu Can not read Serial Data!
Port 5: cu Can not read Serial Data!
Port 6: cu Can not read Serial Data!
Port 7: cu
Port 8: cu Can not read Serial Data!
Port 9: cu Can not read Serial Data!
Port 10: cu Can not read Serial Data!
Port 11: cu Can not read Serial Data!
Port 12: cu Can not read Serial Data!
Port 13: cu Can not read Serial Data!
Port 14: cu Can not read Serial Data!
Port 15: id (sw) Vendor: AVAGO Serial No: A907419V98 Speed: 100, 200,400 _MB / s
Port 16: id (sw) Vendor: AVAGO Serial No: A907419VKR Speed: 100, 200,400 _MB / s
Port 17: id (sw) Vendor: AVAGO Serial No: A907419YN0 Speed: 100, 200,400 _MB / s
Port 18: id (sw) Vendor: AVAGO Serial No: A907419VKW Speed: 100, 200,400 _MB / s
Port 19: -
SAN_Switch_1: adm> sfpshow
Port 9: id (sw) Vendor: FINISAR CORP. Serial No: PCB312M Speed: 100, 200,400 _MB / s
Port 10: id (sw) Vendor: FINISAR CORP. Serial No: PCB3TZA Speed: 100, 200,400 _MB / s
Port 12: id (sw) Vendor: FINISAR CORP. Serial No: PCB3YCU Speed: 100, 200,400 _MB / s
Port 14: -
Port 15: id (sw) Vendor: FINISAR CORP. Serial No: PCB2T0E Speed: 100, 200,400 _MB / s
SAN_Switch_1 1-8 transceiver SFP port is not taken out.
Valued Contributor
Hi,
I suppose that this issue occurs because of the old FOS code. Newer release have added the opetion "-f" that forces the switch to read the SFP prom, but with older releasese, the only way to make the switch read the SFP info is by reseating the SFP.
Usually even though sfpshow does not show the SFP info, the SFP itself works fine.
