Anonymous
need to set only default gateway for Brocade 300 Switch .. wil swithcl reboot after the ipaddrset %3F
need to set only default gateway for Brocade 300 Switch .. wil the swithc reboot after the ipaddrset ?
Anonymous
Re: need to set only default gateway for Brocade 300 Switch .. wil swithcl reboot after the ipaddrset %3F
FW running on 6.3.1c
Occasional Contributor
[ Edited ]
I did it on 6.4.3 a day or two ago and no reboot was required, you should be good to go.
Typically when a reboot or a major disruption will occur with will get a notice asking if you are sure you want to do this.
