Contributor
my switch port won't go 8gb
Im having issues with one of my switch ports on one particuklar blade server. Whatever I do I can't get the port to go to a full 8gb abd come on line.
External Moderator
Re: my switch port won't go 8gb
did you check the SFP on affected port ?
with "sfpshow" command can you check if correct SFP is inserted.
TechHelp24
Contributor
Please, also check OM category of fibre cable.
Valued Contributor
Is it a cupper port or an optical one?
Occasional Visitor
What FOS is the switch on? Also I have seen this issue on driver and firmware on some HBA's one was a Emulex HBA and requiered the latest firmware and download to correct the issue. There is also a FOS update I have seen resolve this problem.
