Anonymous
is there a problem with webtools .. when java 8 U40 installed?
Hi,
I have switch with FOS 7.3.1 and java 8 U40..
It give this error..all java setting were correctly set..
exception encountered during initialization com.brocade.web.secsan.securesanExecption:white space not allowed
i uninstalled the java 8 U40.. and installed the java 7 with U55..now it started working without issue..
Problem is .. java updates happens automatically.. if again it goes to java 8 U40 . i am sure webtools will through error..
Can you please tell me, is there any problem with Java 8 U40?
Regards,
Niklesh Reddy
Valued Contributor
Re: is there a problem with webtools .. when java 8 U40 installed?
java 7.45 shoud work...
Anonymous
Hi Alex,
Java 7 u45 works .. but we want java 8 u 40
Regards,
Niklesh Reddy
Occasional Contributor
I am in the same boat here, we are required to run the most up-to-date version of JAVA (8_51 for now) and cannot use web tools. Is ther e a work around? How far back before the compatability issues go away? ...there is no way I could go back to 7...
Valued Contributor
Hi,
check the release notes of the FOS version installed on the switch, it shows the supported java version. To check if any version supports Java 8, you have to review the Release notes of the newest FOS codes release by Brocade, to see if by ugprading you could make it work with Java 8.
rgds,
Felipon
Frequent Contributor
has java ever worked is a more accurate question :))
Anonymous
Hi,
Once FOS 7.4.0a was released. I told our customer to upgrade the Fos and it got fixed.
Webtools is working with Java 8 u40 .
Regards,
Niklesh Reddy
