Occasional Contributor
info on FC FC routing
Hi to all,
i have two SAN environment completely different about the FC-FC connection, both the environment have 2 site that are connected via FC-FC through DWDM, but while in the ENVIRONMENT-1 the two FCR (Brocade 7500) make a single backbone fabric that is separeted from the edge fabric, in the ENVIRONMENT-2 the two FCR (Brocade 7500) they are part of the edge fabric and does not exist any backbone fabric. Both environment are in production and work correctly.
I try to outline the environment
ENVIRONMENT-1
SITE-1        SITE-2
FABRIC1   |          |              BB FABRIC               |                      |   FABRIC2 |
dcx-8510 |          | mpr7500-1 <>  mpr7500-2 |                      |dcx-8510  |
                |         |                     2DWDM            |                      |                 |
ENVIRONMENT-2
FABRIC1  |        |FABRIC2    |
dcx8510 |        |dcx8510   |
dcx         |        |dcx           |
mpr7500|                              <>                                            |mpr7500   |
---------------                              2DWDM                                     -------------------
The question is: what is the better configuration and why ENVIRONMENT-1 and ENVIRONMENT-2 are different, there are 2 different architectural designe?
Thanks a lot to all
Best Regards
Broadcom Moderator
Re: info on FC FC routing
Hi Alessandro,
the first environment, where 2 x 7500 is part of backbone fabric, provice isolation between two edge fabric.
For example, when xWDM (or FCIP) is unstable and goes down temporarily, the FCR does not send out RSCN
that the links is down directly. So, you have seperate error domain - one for each edge fabrics so issues is
isolated to the edge fabrics. And you can have different FOS code level, and settings if needed in the different
edge. Best practices is 80/20 traffic distribution - 20% of traffic at most should go over the LSAN zones.
The second environment, where the 7500 are part of the fabrics, you have a singel error domain and not isolation.
If a lot of traffic goes over the xWDM, this is preferred.  Best practice is same FOS level and settings should be the same.
Easier to manage, no requirement for LSAN zones and less complex.
Dependent on your requirements and traffic patters between the two sites, determine which solution is best.
Notice the FOS 6.x is not supported in same fabrics as FOS 8.x (connected via ISLs directly or indirectly) but
require a FCR to isolate from FOS 8.x
