Anonymous
how to trunk 2 port on switch
I have to trunk 2 port on switch with 2 HBA on host to provide full 4 Gb bandwidth. Is any one have any idea how to trunk the port not for ISL.
Anonymous
Re: how to trunk 2 port on switch
Trunking is only for ISL... If you want to have more speed on your host, you should add a software that can enables load balancing on several HBAs.
Anonymous
yes, in this case, depending on the storage array ,you would want to present the storgae to multi front end ports and zone the hba's to see it down each front end port. Then use a load balncing software like powerpath to load balance the I/O down the least congested path.
