Broadcom
how to trblshoot and solve it
i have two switch use trunking ,switch 19 display some porterr, but switch 18 just have ENC out
how can i know what happened and how to solve the issue
switchName: SWITCH_18
switchType: 66.1
switchState: Online
switchMode: Native
switchRole: Subordinate
switchDomain: 18
switchId: fffc12
switchWwn: 10:00:00:05:33:fc:b0:0b
zoning: ON (DOMAIN1_2)
switchBeacon: OFF
FC Router: OFF
Allow XISL Use: OFF
LS Attributes: [FID: 128, Base Switch: No, Default Switch: Yes]
Area Port Media Speed State Proto
0 0 id N8 Online F-Port 21:00:00:24:ff:09:44:95
1 1 id N8 Online F-Port 21:00:00:24:ff:09:45:90
2 2 id N8 No_Light
3 3 id N4 Online F-Port 50:06:0e:80:10:22:d0:c0
4 4 id N8 Online F-Port 21:00:00:24:ff:09:45:e9
5 5 id N8 Online F-Port 21:00:00:24:ff:09:44:68
6 6 id N8 No_Light
7 7 id N4 Online F-Port 50:06:0e:80:10:22:d0:c1
8 8 id N8 No_Light
9 9 id N2 Online F-Port 10:00:00:00:c9:4e:6d:34
10 10 id N8 Online F-Port 10:00:00:90:fa:38:5e:0e
11 11 id N8 No_Light
12 12 id N8 No_Light
13 13 id N2 Online F-Port 10:00:00:00:c9:4a:0c:a2
14 14 id N2 Online F-Port 10:00:00:00:c9:4c:f3:e9
15 15 id N2 Online F-Port 10:00:00:00:c9:40:52:6e
16 16 id N8 No_Light
17 17 id N8 No_Light
18 18 id N8 No_Light
19 19 id N8 No_Light
20 20 id N8 Online F-Port 21:00:00:24:ff:0d:68:0c
21 21 id N8 No_Light
22 22 id N8 No_Light
23 23 id N8 No_Light
24 24 id N8 No_Light
25 25 id N8 No_Light
26 26 id N4 Online F-Port 50:06:01:68:3b:a0:71:0d
27 27 id N8 No_Light
28 28 id N8 No_Light
29 29 id N4 Online F-Port 50:06:01:60:3b:a0:71:0d
30 30 id N8 No_Light
31 31 id N8 No_Light
32 32 id N8 Online E-Port (Trunk port, master is Port 36 )
33 33 id N8 No_Light
34 34 id N4 Online F-Port 20:24:00:a0:b8:76:9f:df
35 35 id N4 Online F-Port 20:25:00:a0:b8:76:9f:df
36 36 id N8 Online E-Port 10:00:00:27:f8:d6:cc:02 "SWITCH_19" (downstream)(Trunk master)
37 37 id N4 Online E-Port 10:00:00:05:1e:35:a6:72 "SWITCH_14" (Trunk master)
38 38 id N8 Online E-Port (Trunk port, master is Port 39 )
39 39 id N8 Online E-Port 10:00:00:05:33:3b:55:b6 "SWITCH_17" (upstream)(Trunk master)
SWITCH_18:FID128:admin> porterrshow
frames enc crc crc too too bad enc disc link loss loss frjt fbsy
tx rx in err g_eof shrt long eof out c3 fail sync sig
0: 201m 12m 0 0 0 0 0 0 0 0 0 0 0 0 0
1: 339m 15m 0 0 0 0 0 0 0 0 0 0 0 0 0
2: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
3: 266m 438m 0 0 0 0 0 0 0 0 0 0 0 0 0
4: 23m 30m 0 0 0 0 0 0 0 0 0 0 0 0 0
5: 46m 122m 0 0 0 0 0 0 0 0 0 0 0 0 0
6: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
7: 179m 84m 0 0 0 0 0 0 0 0 0 0 0 0 0
8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
9: 13m 1.4m 0 0 0 0 0 0 0 0 0 0 0 0 0
10: 51k 78k 0 0 0 0 0 0 0 0 0 0 0 0 0
11: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
12: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
13: 776m 49m 0 0 0 0 0 0 0 0 0 0 0 0 0
14: 181k 462k 0 0 0 0 0 0 0 0 0 0 0 0 0
15: 141k 334k 0 0 0 0 0 0 0 0 0 0 0 0 0
16: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
17: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
19: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
20: 6.9m 17m 0 0 0 0 0 0 0 0 0 0 0 0 0
21: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
22: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
23: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
24: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
25: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
26: 109k 215k 0 0 0 0 0 0 0 0 0 0 0 0 0
27: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
28: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
29: 126m 733m 0 0 0 0 0 0 0 0 0 0 0 0 0
30: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
31: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
32: 119m 28m 0 0 0 0 0 0 7 0 0 0 0 0 0
33: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
34: 150m 128m 0 0 0 0 0 0 0 0 0 0 0 0 0
35: 1.4m 1.6m 0 0 0 0 0 0 0 0 0 0 0 0 0
36: 1.0g 182m 0 0 0 0 0 0 0 0 0 0 0 0 0
37: 493m 681m 0 0 0 0 0 0 0 0 0 0 0 0 0
38: 50m 518m 0 0 0 0 0 0 0 0 0 0 0 0 0
39: 245m 1.0g 0 0 0 0 0 0 0 0 0 0 0 0 0
switchName: SWITCH_19
switchType: 71.2
switchState: Online
switchMode: Native
switchDomain: 19
switchId: fffc13
switchWwn: 10:00:00:27:f8:d6:cc:02
switchBeacon: OFF
0 0 id N4 Online F-Port 21:00:00:24:ff:04:79:d5
1 1 id N8 No_Light
2 2 id N8 No_Light
3 3 id N8 No_Light
4 4 id N8 No_Light
5 5 id N8 No_Light
6 6 id N8 Online F-Port 50:05:07:68:02:16:67:dd
7 7 id N2 Online L-Port 1 public
8 8 id N8 No_Light
9 9 id N8 No_Light
10 10 id N8 No_Light
11 11 id N4 Online F-Port 50:03:08:c0:9e:df:f0:9d
12 12 id N2 Online L-Port 1 public
13 13 id N8 No_Light
14 14 id N8 No_Light
15 15 id N4 Online F-Port 50:03:08:c0:9e:df:f0:99
16 16 id N8 Online F-Port 21:00:00:24:ff:4d:48:a0
19 19 id N4 Online F-Port 50:03:08:c0:9e:e0:00:9d
20 20 id N8 No_Light
21 21 id N8 Online F-Port 50:05:07:68:02:16:67:de
22 22 id N8 Online E-Port (Trunk port, master is Port 23 )
23 23 id N8 Online E-Port 10:00:00:05:33:fc:b0:0b "SWITCH_18" (upstream)(Trunk master)
SWITCH_19:admin> porterrshow
0: 1.2g 2.1g 0 0 0 0 0 0 0 0 0 0 0 0 0
6: 18m 320m 0 0 0 0 0 0 0 0 0 0 0 0 0
7: 742m 45m 0 0 0 0 0 0 0 0 0 0 0 0 0
10: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
11: 4.7k 8.2k 0 0 0 0 0 0 0 0 0 0 0 0 0
12: 571m 34m 0 0 0 0 0 0 0 0 0 0 0 0 0
13: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
14: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
15: 461m 28m 0 0 0 0 0 0 0 0 0 0 0 0 0
16: 244m 3.8m 0 0 0 0 0 0 0 0 0 0 0 0 0
19: 363m 22m 0 0 0 0 0 0 0 0 0 0 0 0 0
20: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
21: 73m 212m 0 0 0 0 0 0 0 0 0 0 0 0 0
22: 35m 120m 81 56 53 0 0 3 7 0 0 0 0 0 0
23: 216m 1.0g 3 3 3 0 0 0 0 0 0 0 0 0 0
Former Brocadian
Re: how to trblshoot and solve it
The enc_out errors are commonly seen when ports bounce. The errors of concern are the enc_in and crc g_eof on switch 19 ports 22 and 23. If the errors continue to increment it indicates a physical layer issue on those connections. It could be sfp on either end or cable/infrastructure between the switches. Try cleaning/reseating cable connections or replacing cable or sfp on one side until errors clear up.
