Anonymous
how to remove down switches
We have 6 switches that have been decommisioned and are turned off.
External Moderator
Re: how to remove down switches
krakpot,marked the removed switch, right mouse tast and select delete.
TechHelp24
Anonymous
Or when that doesn't work - such as when the removed switch was one that FabMan has identified as its launch switch - then the only option appears to be to delete the fabric from FabMan and then rediscover it. Not ideal, but at least it works!- Alastair
